Can I select the option to protect a snapshot during mount?
It depends.
The Protect Snapshot during mount option is not applicable for 3PAR snapshots. These snapshots are non-persistent because any modification on the snapshot cannot be saved during mount.
For clones, you can use this option so that the changes made to the snapshot during mount are not retained when the snapshot is unmounted.
