Getting Started with the HPE 3PAR StoreServ / Primera / HPE Alletra 9000 Series / HPE GreenLake for Block Storage Array
To set up the HPE 3PAR StoreServ storage array, the HPE Primera storage array, HPE Alletra 9000 Series, or HPE GreenLake for Block storage array, review system requirements, and then add the array in the Commvault Cloud software. Then you can modify the snapshot properties.
  1. Verify that your environment meets the IntelliSnap - System Requirements for HP 3PAR/ Primera / HPE Alletra 9000 Series / HPE GreenLake for Block
  2. Review the Considerations for the HPE 3PAR StoreServ / Primera / HPE Alletra 9000 Series / HPE GreenLake for Block Storage Array
  3. Add the storage array in the CommCell Console. For information, see Configuring the HP 3PAR/ Primera / HPE Alletra 9000 Series / HPE GreenLake for Block Array Using Arrays page.
  4. To customize the array to your environment, you can modify the properties that control snapshot operations. See Editing the Properties of the HP 3PAR/ Primera / HPE Alletra 9000 Series / HPE GreenLake for Block Array.
