Logging Into the Commvault MSP Portal Using a PIN
If your administrator notifies you that two-factor authentication (which is a form of multi-factor authentication) is enabled in the Commvault Cloud environment, a password and a personal identification number (PIN) are required to log in.
You must acquire a PIN through email or through a PIN generating tool.
  1. Go to msp.metallic.io.
    The Login page appears.
  2. In the Email field, enter your email address.
  3. In the Password field, enter your password
  4. In the PIN field, enter the PIN.
  5. Click Login.
    The Commvault MSP Portal appears.
