System Requirements for the Commvault OVA for VMware
Verify that your environment meets the system requirements for using the Commvault Cloud Open Virtualization Appliance (OVA) for VMware.
  • Deploy the OVA on a Version 7.0 ESXi host or a more recent version.
  • The OVA specifies a virtual appliance with the minimum required resources:
    • 4 vCPUs
    • 16 GB of RAM
    • 100 GB thin provisioned disk
    After you deploy the OVA, you can adjust the virtual machine resources as needed to meet your backup environment needs.
  • You can deploy the OVA using VMware vCenter Server, VMware vSphere, or VMware Fusion. Based on the interface you choose, the deployment steps might differ.
