Before you configure your storage array, verify that your system meets the following requirements.
Licenses
Install the following licenses.
Array |
Snapshot Type |
License |
HPE 3PAR StoreServ |
Virtual Copy |
Virtual Copy Install the Thin Provisioning (4096G) license for the Thin Provisioning option for cloning |
HPE Primera |
Virtual Copy |
HPE Alletra 9000 Series |
Virtual Copy |
HPE GreenLake for Block |
Virtual Copy |
Version and Firmware
Ensure that you are using compatible versions and firmware.
Array |
Version and Firmware |
HPE 3PAR StoreServ models |
HPE Primera |
*Supports only Linux and VMWare systems with iSCSI protocol. **Replication for this array version is not supported by Commvault due to the behavioral changes done by HPE in virtual volume sets and RCG. |
**Replication for this version of array is pending validation by Commvault.
Protocols
Ensure that at least one of the following protocols is available.
Array |
Protocol |
HPE Primera |
For the iSCSI protocol, on the client and proxy computers, configure the iSCSI initiator to access the storage array.
Software
Install the following software components.
Array |
Required Software |
None |
HPE Primera |
None |
None |
None |
Ports
For snap-based operations, open port 5989 for HTTPS and port 5988 for HTTP between the CommServe computer and the storage array and between the MediaAgent and the storage array.
