The following sections provide context-sensitive help information related to this feature.
Blackout Window
Use this dialog box to add, modify, or delete operation rules for system operations.
If the time zone of a client differs from the time zone of the CommServe, then the time zone of the client is honored unless the blackout window operation rule is set at the CommServe level. If the blackout window is set at the CommServe level, the time zone of the CommServe level is honored.
Name
The friendly name assigned to the blackout window.
Operations
Displays the operations included in the operation rule.
Do not run days of week and time interval
Displays the times and week days when the operations included in the blackout window will not run.
Add
Click this button to add an operation rule from the Operation Rule Details dialog box.
Modify
Click this button to modify an operation rule from the Operation Rule Details dialog box.
Delete
Click this button to delete an operation rule.
Ignore Blackout Rules at Higher Levels (not applicable at the CommServe, client group, and schedule policy levels)
Select this option to disable all blackout window operation rules set at levels above the currently selected CommCell entity.
Use this dialog box to specify the details of an operation rule.
Name
Type a friendly name for this operation rule.
Operations
Select from among the following operation rule choices. You may also select all of the operation rules by selecting All. Not all operation rules are available at all levels (for the operation rules supported at each level, see Agents That Support the Operation Window):
Full Data Management (full backups)
Non Full Data Management (non full backups)
Transaction log backup
Backup Copy
Data Recovery
Data Pruning
Data Analytics
Synthetic Full
Auxiliary Copy
If a blackout window is defined in the schedule policy, the auxiliary copy operation always follows the MediaAgent’s time zone.
If only the Transaction log backup operation is selected for the blackout window, the Do not submit job checkbox will not be available.
Disaster Recovery Backup
Data Verification
Delete Backup and Archive Data Using the CommCell Console
Erase Spare Media
Offline Content Indexing
Information Management
Media Refreshing
Do not run intervals
Allows you to select the date and time that these operations should not run.
Start Date
Select the start day, month, and year of the interval for this operation rule.
End Date
Select the end day, month, and year of the interval for this operation rule.
From Time
The start time of this operation rule.
To Time
The end time of this operation rule.
Weeks
If a monthly time interval is defined, the week of the month for the time interval. For example, do not run an operation on the second and the last Sunday of the month.
Days
If a weekly time interval is defined, the day of the week for the time interval. For example, do not run an operation on Sunday and Monday.
Add
Add a time interval from the Do not run time interval dialog box.
Modify
Modify a time interval from the Do not run time interval dialog box.
Delete
Click this button to delete a time interval from this operation rule.
Do not submit job
Skips a scheduled job. If the Do not submit job check box is not selected, a job is created and queued. When the blackout window ends, the job starts.
If the Do no submit job check box is selected and an interactive job is submitted, the Commvault software queues the interactive job during the blackout window.
Use this dialog box to set the time interval (in hours and minutes) for the selected days that the operation rule should not run.
Recurrence
Define the day of the week.
Weekly
Days
Duration
Define the time interval.
Start Time
Specify the start time of the interval.
End Time
Specify the end time of the interval. Note that the end time of the interval must be greater than the start time.
Add
Click this button to add the specified time interval to the Operation Rule Details dialog box. This button allows you to add multiple operation rules without closing this dialog box.
