Verify that your environment meets the following system requirements for the MySQL agent.
Database Application
Application |
Version |
MySQL, all editions (Community, Enterprise, Standard, Classic) |
5.5.x, 5.6.x, 5.7.x, 8.0.x, 8.4.x |
Percona MySQL |
MariaDB |
5.5.x, 10.x.x, 11.x.x |
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
MySQL Community Server, Percona Server, Enterprise, Standard, or Classic Edition 8.0.x and 8.4.x
Linux
Important
If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
You can install a Percona server only on Linux operating systems.
Operating system |
Processor architecture |
Amazon Linux 2023 AMI |
Amazon Linux 2 AMI (HVM) - Kernel 5.10, SSD Volume Type |
Debian 11.x |
Debian 10.x |
Debian 9.x |
Red Hat Enterprise Linux 9.x |
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 8.x |
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 7.x with glibc 2.17.x |
Rocky Linux 9.3 |
SuSE Linux 15 SP6 |
SuSE Linux 15.0 |
SuSE Linux 15 SP6 |
SuSE Linux 12 Initial Release |
Ubuntu 14.04 LTS |
Ubuntu 16.04 LTS |
Ubuntu 18.04 LTS |
Ubuntu 20.04 LTS |
Ubuntu 22.04 LTS |
x64 |
Amazon Linux 2023 AMI supports MySQL database version 8.x on ARM64 and x86.
Windows
Operating system |
Windows Server 2019 Editions |
All Windows-compatible processors are supported |
Windows Server 2016 Editions |
MySQL Community Server, Percona Server, Enterprise, Standard, or Classic Edition 5.5.x, 5.6.x, 5.7.x, 8.0.x and 8.4.x; MariaDB 5.5.x, 10.0.x, 10.6.x to 11.x
FreeBSD
Operating system |
FreeBSD 10.x |
FreeBSD 9.x |
HP-UX
Operating system |
HP-UX 11i v3 (11.31) |
Itanium |
Linux
Important
On Ubuntu 9.x 64-bit computers, you must install the libstdc++.so.5 compatibility package. To install the package, use the following command:
[root]# sudo apt-get install libstdc++5 -
On Ubuntu and Debian computers, install the latest packages for the operating system before installing the Agent. To install the latest packages, use the following command:
[root]# apt-get upgrade -
Operating system |
Asianux 4 |
Debian 11.x |
Debian 10.x |
Debian 9.x |
Debian 8.x |
Debian 7.x |
Debian 6.x with glibc 2.11.x |
Debian 5.x |
Gentoo release 10.1 with glibc 2.6.x |
Red Hat Enterprise Linux/Oracle Linux Enterprise/CentOS 9.x |
Source Mage Linux |
SuSE Linux 15 SP6 |
SuSE Linux 12.0 |
SuSE Linux 11 (Initial Release/SP1 and later SPs) with glibc 2.9.x and higher |
Ubuntu 8.04 |
Ubuntu 9.04 |
Ubuntu 10.04 LTS |
Ubuntu 12.04 LTS |
Ubuntu 14.04 LTS |
Ubuntu 16.04 LTS |
Ubuntu 18.04 LTS |
Ubuntu 20.04 LTS |
Ubuntu 22.04 LTS |
x64 |
Important
You must install an additional mariadb-client-compat package on the MariaDB server for versions 11.x and later.
Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system |
Solaris 11.x |
Solaris 10 Update 6 or equivalent |
Windows
Operating system |
Hard Drive
Component |
Space required |
Software |
1 GB |
Job results folder |
256 MB |
Log folder |
256 MB |
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Block-Level Backups
Block-level backups are supported only on Linux platforms. For supported Linux kernel version details, see MySQL Block-Level Backup.
Block-level backups are not supported on the Network File System (NFS).
Software That Is Automatically Installed
File System Agent
The file system agent is automatically installed during the installation of this software, if it is not already installed. For file system system requirements, see the following:
The operating system must have been installed with at least the user level software option selected.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Windows 10 and Windows Server 2016, because these versions have the Universal C Runtime already installed.
KB2919355
KB2939087
KB2975061
KB2999226
DISCLAIMER
