Verify that your environment meets the system requirements for SAP Oracle.
Nested mount points are not supported for Azure NetApp Files.
Operating System
Important
Use the most recent version of the operating system that is listed. The Commvault software fully supports the most recent version of an operating system, until the vendor ends support. More recent versions of the Commvault software might not install on operating systems that are not supported by the vendor anymore. For information about the support lifecycle of an operating system, contact the vendor.
SAP BR*Tools 7.40 and Higher Versions for Oracle 12c (V12.2), Oracle 18c, Oracle 19c
For Oracle 12.2, you must install BR*Tools 7.40 patch level 32 or a more recent version. For information about additional SAP requirements with Oracle 12.2, see SAP Note 2470660.
For Oracle 18c, you must install BR*Tools 7.40 patch level 37 or a more recent version. For information about additional SAP requirements with Oracle 18c, see SAP Notes 2705272, 2763733, and 2660020.
For Oracle 19c, you must install BR*Tools 7.40 patch level 40 or a more recent version. For information about additional SAP requirements with Oracle 19c, see SAP Notes 2799900, 2817074, and 2763733.
AIX
Data protection on Logical Partitioning (LPAR) and Workload Partitioning (WPAR) is supported.
Operating system |
Processor architecture |
AIX 7.3 64-bit TL 00 SP1 |
PowerPC |
AIX 7.2 64-bit TL 09 SP 1, TL05 |
PowerPC |
AIX 7.1 64-bit TL03 SP4 |
PowerPC |
AIX 6.1 64-bit TL09 SP4 |
PowerPC |
HP-UX
Operating system |
HP-UX 11i v3 (11.31) |
Itanium |
Linux
Important
If you have SELinux enabled on the client computer, create the SELinux policy module as a root user before performing a backup. The SELinux Development package must be installed on the client.
Operating system |
Oracle Linux 9.x with glibc 2.34.x or a more recent version |
Oracle Linux 8.x with glibc 2.17.x or a more recent version |
Oracle Linux 7.x with glibc 2.17.x or a more recent version |
Red Hat Enterprise Linux 8.x with glibc 2.28.x |
Red Hat Enterprise Linux 7.x |
SuSE Linux 12 SP1 Enterprise Server |
SuSE Linux 15 (Initial Release/SP1 and later SPs) with glibc 2.26.x and higher |
Oracle Solaris
In a UNIX virtualization environment using Solaris, you can back up and restore data in both global and non-global zones.
Operating system |
Oracle Solaris 11.2 SRU 5.5 |
Oracle Solaris 10 Update 11 |
Windows
Operating system |
Windows Server 2022 Editions |
All Windows-compatible processors are supported |
Windows Server 2019 Editions |
Windows Server 2016 x64 Editions |
SAP BR*Tools 7.20 (42), 7.20 (40), 7.40(46), 7.40 (14) for Oracle 12c (V12.1), 11g (R1, R2, or a More Recent Version)
AIX
Operating system |
AIX 7.2 64-bit |
PowerPC |
AIX 7.1 64-bit |
PowerPC |
AIX 6.1 TL 02 SP00 or higher, 64-bit |
PowerPC |
HP-UX
Operating system |
Itanium |
HP-UX 11i v1 (11.23) |
Itanium |
Linux
Important
Operating system |
Red Hat Enterprise Linux/CentOS 7.x with glibc 2.17.x or a more recent version You must have Oracle v11.2.0.4 or a more recent version, with BR*Tools v7.20 (40) or v7.40 (14). |
SuSE Linux 12 (Initial Release/SP1/SP2/SP3/SP4/SP5) with glibc 2.19.x |
SuSE Linux 11 (Initial Release/SP1 and later SPs) with glibc 2.9.x and higher |
Solaris
Operating system |
Solaris 11.x |
Solaris 10 Update 6 or equivalent |
Sparc T/M series |
x64 |
Windows
Operating system |
Windows Server 2016 Editions |
SAP BR*Tools 7.20(42) or Higher for Oracle 10g (R1, R2 or a More Recent Version)
AIX
Operating system |
AIX 7.2 64-bit |
PowerPC |
AIX 7.1 64-bit |
PowerPC |
PowerPC |
HP-UX
Operating system |
Itanium |
Itanium |
Linux
Important
Operating system |
Solaris
Operating system |
Solaris 11.x |
x64 |
Sparc T/M series |
Windows
Operating system |
Windows Server 2016 Editions Nano Servers are not supported. For more information, see Considerations for Windows Server 2016. |
Hard Drive
Component |
Space required |
Software |
2 GB |
Job results folder |
256 MB |
Log folder |
256 MB |
Memory (RAM)
2 GB or more
Clustering
If clustering is supported by the operating system, you can install the software on a cluster. For information about supported cluster types, see Support for Cluster Configuration.
Software That Is Automatically Installed
File System Agent
The file system agent is automatically installed during the installation of this software, if it is not already installed. For file system system requirements, see the following:
The operating system must have been installed with at least the user level software option selected.
.NET Framework
On most versions of Windows, the .NET Framework 4.7 is automatically installed.
Microsoft Visual C++ Redistributable 2017
Starting with Service Pack 18, Microsoft Visual C++ Redistributable 2017 (vcredist2017.exe) is automatically installed.
If a computer does not have the most recent Windows updates, the installation of Microsoft Visual C++ Redistributable 2017 will fail in installing Universal C Runtime. The following Windows updates must be installed to prevent the installation failure. The updates are not required on the most recent Windows operating system versions, such as Windows 10 and Windows Server 2016, because these versions have the Universal C Runtime already installed.
KB2919355
KB2939087
KB2975061
KB2999226
DISCLAIMER
